need4speed Posted August 20, 2009 Share Posted August 20, 2009 Where can the serial numbers for gearboxes and transferboxes be found. I know what numbers i need to look for i just cant seem to be able to find them on my gearbox. maybe its corroded so much i cant see them.. Also, is there a transfer box that only has forward/aft lever movement as opposed to the more regular forward/aft AND side-to-side lever movement? Quote Link to comment Share on other sites More sharing options...
errol209 Posted August 20, 2009 Share Posted August 20, 2009 First question: Defender_90_110_WSM_book1. p7 pdf.pdf Second question - pass. A Defender without selectable difflock? 2wd only? Quote Link to comment Share on other sites More sharing options...
need4speed Posted August 20, 2009 Author Share Posted August 20, 2009 just had another look. its a borg warner transfer box. permanent 4x4. viscous coupling though. should i use this along with my V8 or swap to usual lt230? ideas peeps? Quote Link to comment Share on other sites More sharing options...
western Posted August 20, 2009 Share Posted August 20, 2009 RR Classic used those with a V8 & auto seemed to work OK in those. Quote Link to comment Share on other sites More sharing options...
