Ruuman Posted August 25, 2009 Share Posted August 25, 2009 Firstly this is a warning, don't trust cheapy bendy torque wrenches on ebay, as always you get what you pay for so swapping my injectors on my 200tdi 90 all went fairly smoothly until I started torquing the clamp on no 1 back up. of course it sheared, then started to rain and then a screw extractor broke off in it, you know the drill. I needed to move it from blocking the drive, so found a long M8 bolt and used the original nut to reclamp. Now speaking to landrover today they want 5quid for the stud and even looking at a few parts suppliers it ends up similar money, I can only assume something is quite special with this stud. My new stud arrives thursday, will it be ok to use till then? Oh also on a side not, was very impressed with the service from united diesel for the set of recon injectors (no link/stake in company, bla, bla) thanks Ruu Quote Link to comment Share on other sites More sharing options...
errol209 Posted August 25, 2009 Share Posted August 25, 2009 I wouldn't go far, as it'll probably work loose quite quickly, but otherwise: Landys were never pretty anyway Quote Link to comment Share on other sites More sharing options...
ejparrott Posted August 25, 2009 Share Posted August 25, 2009 nah dont think so, if you were to use a spring washer under the nut, and some studlock too, its unlike to move, after all, whats the difference? Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted August 25, 2009 Share Posted August 25, 2009 It should be fine if the bolt and nut are grade 8.8 or higher. Quote Link to comment Share on other sites More sharing options...
white90 Posted August 25, 2009 Share Posted August 25, 2009 Yep and I snapped one of those as well ages ago. not loads of tension on them anyway. it looks fine till you can get a replacement stud. Quote Link to comment Share on other sites More sharing options...
Ruuman Posted August 25, 2009 Author Share Posted August 25, 2009 cool, cheers everyone Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 25, 2009 Share Posted August 25, 2009 Looks a quality bodge to me I'd leave it like that for months Les. Quote Link to comment Share on other sites More sharing options...
