EggNChips Posted August 29, 2009 Share Posted August 29, 2009 Hi, Got a 2001 TD4 and the ABS,TC & HDC lights are on. When you switch on the ignition, the ABS pump seems to be activated for an awful long time, anybody got any ideas??? Quote Link to comment Share on other sites More sharing options...
rustymark Posted August 29, 2009 Share Posted August 29, 2009 Hi If you do a search on here for the 3 amigies you'll find loads of useful info. Briefly - the three lights signify a fault somewhere in the abs circuit. Can be caused by 1. faulty abs wheel sensor(s) 2. faulty brake light switch 3 faulty HDC switch or wiring disconnected on gearstick 4 ABS pump module fault. Had this three times on mine now they are my little friends! Message me if you get stuck.... Quote Link to comment Share on other sites More sharing options...
mcdan Posted September 30, 2009 Share Posted September 30, 2009 ..I know that the three amigos's problem is often by the sensor of ABS, dust & rust,expecialy on discovery on front right whell..no one explain why, but this is... Quote Link to comment Share on other sites More sharing options...
jjay Posted October 18, 2009 Share Posted October 18, 2009 just a shot in the dark as dont know anything about the diesel versions but... when i disconnected the tps (throttle position sensor) on my 1.8 petrol version the 3 amigo lights came on straight away! which as you can gather is nothing to do with the abs or hill descent control! so just double check the wiring around the sensor... just a thought! Quote Link to comment Share on other sites More sharing options...
EggNChips Posted October 18, 2009 Author Share Posted October 18, 2009 just a shot in the dark as dont know anything about the diesel versions but... when i disconnected the tps (throttle position sensor) on my 1.8 petrol version the 3 amigo lights came on straight away! which as you can gather is nothing to do with the abs or hill descent control! so just double check the wiring around the sensor... just a thought! It's all fixed, I bought the car with a blown IRD box because the lunatic that owned it had put different size tyres on the front and the back! The HDC only works when the throttle, clutch and brake are not depressed so presumably it uses the TPS to sense if the throttle is pressed. Cheers anyway. Quote Link to comment Share on other sites More sharing options...
mcdan Posted October 19, 2009 Share Posted October 19, 2009 .... I bought the car with a blown IRD box because the lunatic that owned it had put different size tyres on the front and the back! Th what can you explain more about this?? Quote Link to comment Share on other sites More sharing options...
EggNChips Posted October 20, 2009 Author Share Posted October 20, 2009 what can you explain more about this?? Yeah, the previous owner had put different width and profile tyres on the back as the front. This means that the back wheels are rotating at different rates to the front. The viscous coupling then locks up because of the wheel slip and the IRD box winds up eventually stripping the teeth of the Crownwheel and pinion. It also causes problems with the Traction Control because the rear and front wheels are rotating at different rates. Quote Link to comment Share on other sites More sharing options...
mcdan Posted October 20, 2009 Share Posted October 20, 2009 ..about ABS...I realized a simply circuit to disconect the ABS central unit, just a relè (normaly close)with a swicht that put it ON and so disconnect the power supply of ABS's electronic control,just to disconnect ABS service in O.R. so i can block the wheels. Naturally the HDC don't work. Someone told me that is better to reconnected the ABS electronic service (put the swicht off) whit keypanel is OFF. It's very interesting to use in a short discend when HDC is to long to drive you down. What do you think? P:S: I use it a very few times Quote Link to comment Share on other sites More sharing options...
