Ian M Posted August 30, 2009 Share Posted August 30, 2009 does anyone know if the flywheel from the v8 3.9 auto is the same a 300tdi auto? and also if the bell housing mounting holes are the same? Ian Quote Link to comment Share on other sites More sharing options...
Aragorn Posted August 30, 2009 Share Posted August 30, 2009 bellhousing bolt pattern on a V8 is different to a TDi for sure. I doubt the flywheels (well flex plates?) will be the same? Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted August 31, 2009 Share Posted August 31, 2009 Definately not the same - I've got a V8 auto box behind my Tdi, and a big converter ring to match the two. Problem with a converter ring is that the whole thing ends up being longer, so you need to make up the gap between the centre of the flex plate and the end of the crank, too. Quote Link to comment Share on other sites More sharing options...
