gruntus Posted September 18, 2009 Share Posted September 18, 2009 Gents, I have an odd situation with my 90 rebuild . Information: New chassis for a 200TDi with LT77 gearbox (original engine/chassis was a 2.5TD). Original Front Axle and Radius Arms refurbed. Superpro poly bushes. So, the issue I currently have is that the front springs look out of sorts and at an odd angle between the axle and the spring seats (please look at the pictures you may see what I mean). I know that the chassis will drop once the engine goes in but it does look as if the axle (bottom spring locators) is sitting 2cm forward of where it should. I thought it might settle itself in once the engine goes in but when I went to fit the shockies in today they really dont look right or sit in a nice vertical position. Has anyone seen this before? The only thing I can possibly think of is that the superpro bushes are thicker than standard thus "pushing" the radius arm/axle centre line forward. I didnt think there were many differences between the 2.5 TD and the 200TDi and hence radius arms etc should be the same spec? Can anyone confirm? As everything is new kit or refurbed original I thought it would all go in nice and neatly but thats land rovers! I look forward to your help and ideas. Cheers G Quote Link to comment Share on other sites More sharing options...
western Posted September 18, 2009 Share Posted September 18, 2009 I'd leave the radius & trailing arm bolts slack until all the vehicles weight is on the tyres then tighten the radius arm & trailing arm bolts, that will give the vehicle chance to settle on the suspension & align itself. Quote Link to comment Share on other sites More sharing options...
andyb Posted September 18, 2009 Share Posted September 18, 2009 I'm with Western. As you say there is no weight on the suspension yet.....also I notice that you haven't fitted the panhard rod yet; while this won't cause problem shown it will make the axle move all over the show until it is fitted. Quote Link to comment Share on other sites More sharing options...
gruntus Posted September 18, 2009 Author Share Posted September 18, 2009 Thanks for your advice chaps, I had torqued up the radius arms but wil slacken them off again as with the trailing arms. I will leave the shockies out for now as well and add them on once the vehicle starts to fill out. Thanks again G Quote Link to comment Share on other sites More sharing options...
