jagman9965 Posted September 18, 2009 Share Posted September 18, 2009 hi looking at putting a sailsbury rear axel of a 110 do i need to replace the front axel at the same time Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 18, 2009 Share Posted September 18, 2009 No - ratios are the same so it will be fine Propshaft will need some alteration though as the diff nose is a different length. Quote Link to comment Share on other sites More sharing options...
jagman9965 Posted September 19, 2009 Author Share Posted September 19, 2009 No - ratios are the same so it will be fine Propshaft will need some alteration though as the diff nose is a different length. some one told me the front axel of a range rover tdi will fit on the rear does the front prop need to be altered Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 19, 2009 Share Posted September 19, 2009 Rear wheel steering could be an interesting project The RR and Discovery and 90 and 110 front diffs are all the same 3.54:1 unit and are a straight swap as long as they are the correct one of either 10 spline or 24 spline to suit the halfshafts fitted. Quote Link to comment Share on other sites More sharing options...
herdwick. Posted September 20, 2009 Share Posted September 20, 2009 it can be done, but remember to keep your spring seats because 110 and 130 use bigger diameter springs Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 21, 2009 Share Posted September 21, 2009 Anything can be made to fit anything - you need to be a bit more specific Quote Link to comment Share on other sites More sharing options...
