cipx2 Posted September 26, 2009 Share Posted September 26, 2009 It's about the pop rivets used to secure the rubber dust cover as can be seen in Les' pic: I would like to replace them with some sort of demountable solution (better than self tapping screws). I was thinking to something like this: Other ideas please? Quote Link to comment Share on other sites More sharing options...
disco_al Posted September 26, 2009 Share Posted September 26, 2009 what about the plastic rivets that hold the side sill trims on? or some rivnuts and small bolts? Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted September 26, 2009 Share Posted September 26, 2009 We normaly replace the rivets with a 6mm hole and use "U" clips and screws.....nice and easy to remove next time Quote Link to comment Share on other sites More sharing options...
cipx2 Posted September 26, 2009 Author Share Posted September 26, 2009 The plastic rivets used on the sill trims or some other similar rivets (I think their generic class name is snap rivets) can be a option. The reason I didn't include them on my list is mainly because they can't be removed so easily from within the cabin (you have to drill a small hole and use a small self tapping screw as an extractor). But there is at least one kind that can be removed with a small flat screwdriver (used on many vehicles to fix all sorts of covers and other plasticly things in the engine bay). IMO they all are a bit too flimsy for the job. I was also in the middle of considering rivnuts, jack nuts, U clips for self taping screws or captive nuts. I initially put these on 2nd place as they will add a small "bump" and the rubber won't be in a close contact all way round and this could mean whater/dust/etc ingress. Now I'm thinking in glueing some thin plastic sheet strips in between them clips to compensate the "bumps" and equalize the surface all over. For those who don't know what K88 MUD was referring to: The reasons I'm looking for an alternative: - would allow me to remove the rubber cover exclusively from inside the cabin to inspect/check/adjust/test what's underneath (wires, switches, breathers etc) - not removing the gearbox - think of rain/snow/cold/lack of time/middle of nowhere - I want something fast to remove and refit without drilling, taping, too many debris etc - it's reusable (i.e the bits involved don't get destroyed too easy, 1-2 pcs out of the 14 won't be a problem). - in other words, it should be about as simple as on Defenders - bolt on, bolt off but still keep the water and dust out. I'm now leaning towards U clips with captive nuts with strips in between(same as in above picture but with a nut held captive) Thanks for the replies, guys. Quote Link to comment Share on other sites More sharing options...
sweety Posted September 26, 2009 Share Posted September 26, 2009 I was thinking to something like this: Other ideas please? TBH those screw clips can be a right pain to remove once they have been in for a while Quote Link to comment Share on other sites More sharing options...
western Posted September 26, 2009 Share Posted September 26, 2009 The plastic rivets used on the sill trims or some other similar rivets (I think their generic class name is snap rivets) can be a option. The reason I didn't include them on my list is mainly because they can't be removed so easily from within the cabin (you have to drill a small hole and use a small self tapping screw as an extractor). But there is at least one kind that can be removed with a small flat screwdriver (used on many vehicles to fix all sorts of covers and other plasticly things in the engine bay). IMO they all are a bit too flimsy for the job. I was also in the middle of considering rivnuts, jack nuts, U clips for self taping screws or captive nuts. I initially put these on 2nd place as they will add a small "bump" and the rubber won't be in a close contact all way round and this could mean whater/dust/etc ingress. Now I'm thinking in glueing some thin plastic sheet strips in between them clips to compensate the "bumps" and equalize the surface all over. For those who don't know what K88 MUD was referring to: The reasons I'm looking for an alternative: - would allow me to remove the rubber cover exclusively from inside the cabin to inspect/check/adjust/test what's underneath (wires, switches, breathers etc) - not removing the gearbox - think of rain/snow/cold/lack of time/middle of nowhere - I want something fast to remove and refit without drilling, taping, too many debris etc - it's reusable (i.e the bits involved don't get destroyed too easy, 1-2 pcs out of the 14 won't be a problem). - in other words, it should be about as simple as on Defenders - bolt on, bolt off but still keep the water and dust out. I'm now leaning towards U clips with captive nuts with strips in between(same as in above picture but with a nut held captive) Thanks for the replies, guys. you don't need nut strips if you use 'spire' nuts, they accept self tapping screws & act as the nut as well. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted September 26, 2009 Author Share Posted September 26, 2009 I know, it's just that I prefer bolts instead of screws. I trust them more considering vibrations and which one will work itself loose first. Quote Link to comment Share on other sites More sharing options...
thebiglad Posted September 28, 2009 Share Posted September 28, 2009 It's about the pop rivets used to secure the rubber dust cover as can be seen in Les' pic: I would like to replace them with some sort of demountable solution (better than self tapping screws). I was thinking to something like this: Other ideas please? I don't understand why you don't use rivets, I've tried other solutions but have gone back to rivets as I feel they work best - so you have to drill them out next time, so what? Quote Link to comment Share on other sites More sharing options...
