Malcyt Posted September 28, 2009 Share Posted September 28, 2009 Hi, I was at Seven Sisters a week or so ago with Shires .....a great time was had by all. I discovered that the selector for Diff lock was not engaging....with the help of a screw driver we managed to get engaged to have some fun but I now need to fix. It looks like the pin/clip at the top of the selector rod is missing......question is .....is there an easy way to get access? or do I have to take lots apart? It's a defender 90 , 1990. Any tips welcome. Malc Quote Link to comment Share on other sites More sharing options...
western Posted September 28, 2009 Share Posted September 28, 2009 from under the vehicle which is a bit fiddly or lift the gearbox rubber gaiters & work from inside,still a bit fiddly but doable or remove the tunnel panel for more access. Quote Link to comment Share on other sites More sharing options...
crwoody Posted September 28, 2009 Share Posted September 28, 2009 The easiest way I've found to access the diff lock levers & bits is to remove the centre gearbox cover from inside the car, (edit; as Western said, beat me to it!) just a few self-tappers around the edges to undo and it lifts off. Mind you, being a 1990 motor, you may have some rusty ones to give you a headache. Quote Link to comment Share on other sites More sharing options...
Malcyt Posted October 3, 2009 Author Share Posted October 3, 2009 All Sorted............ managed to do if from the top, only had to lift off the rubber cover used a curved darning needle and thread to pull the pin though the hole and a pair of long pliers to pop the split pin in place...... jobs a gooden Quote Link to comment Share on other sites More sharing options...
