ouchie Posted October 14, 2009 Share Posted October 14, 2009 posted a wee while ago about my td5 2004not running properly,have put new fuel pump in about 8 months ago since then seems to have a flat spot at pulling away hot or cold,have changed fuel presure reg valve,maf,injector wiring loom,fuel filter,waste gate sensor,have had it at 2 landrover garages none of them can find a fault.in pulling awya after about 4 or 5 secs it then goes like the clappers thank you. Quote Link to comment Share on other sites More sharing options...
MartinK Posted October 15, 2009 Share Posted October 15, 2009 It does sound like a fuel pump issue, I agree. The symptoms do sound like my own fuel pump issues. Is the pipework all OK between the tank and the engine? I know it's a sod to get at, but maybe you need another look at the fuel pump? Did you do the pump yourself? Maybe worth another look, as this seems to be the root of the problem? My local independant warned me of not using LR OEM pumps - said they created problems...? Quote Link to comment Share on other sites More sharing options...
discomikey Posted October 15, 2009 Share Posted October 15, 2009 i had a similar problem with mine, sounds simple but try looking at your fuel filter lol mikey Quote Link to comment Share on other sites More sharing options...
ouchie Posted October 16, 2009 Author Share Posted October 16, 2009 i had a similar problem with mine, sounds simple but try looking at your fuel filter lol mikey putting landy filter on it tommorow at £39.00 robbed me thinks will let you know thanks . Quote Link to comment Share on other sites More sharing options...
ouchie Posted October 16, 2009 Author Share Posted October 16, 2009 It does sound like a fuel pump issue, I agree. The symptoms do sound like my own fuel pump issues. Is the pipework all OK between the tank and the engine? I know it's a sod to get at, but maybe you need another look at the fuel pump? Did you do the pump yourself? Maybe worth another look, as this seems to be the root of the problem? My local independant warned me of not using LR OEM pumps - said they created problems...? yes i did fit the pump it wasnt to hard to do what do you mean by OEM pump thanks. Quote Link to comment Share on other sites More sharing options...
martinhollings Posted October 17, 2009 Share Posted October 17, 2009 Original Equipment Manufacture (genuine quality) did it cost £150 or £200 Quote Link to comment Share on other sites More sharing options...
ouchie Posted October 18, 2009 Author Share Posted October 18, 2009 Original Equipment Manufacture (genuine quality) did it cost £150 or £200 it cost £195 Quote Link to comment Share on other sites More sharing options...
ouchie Posted October 25, 2009 Author Share Posted October 25, 2009 i had a similar problem with mine, sounds simple but try looking at your fuel filter lol mikey replaced fuel filter made no difference boo hoo. Quote Link to comment Share on other sites More sharing options...
ouchie Posted November 5, 2009 Author Share Posted November 5, 2009 It does sound like a fuel pump issue, I agree. The symptoms do sound like my own fuel pump issues. Is the pipework all OK between the tank and the engine? I know it's a sod to get at, but maybe you need another look at the fuel pump? Did you do the pump yourself? Maybe worth another look, as this seems to be the root of the problem? My local independant warned me of not using LR OEM pumps - said they created problems...? was reading your reply there again was wondering did you replace your pump as well and did you do anything else to your disco thanks. Quote Link to comment Share on other sites More sharing options...
MartinK Posted November 5, 2009 Share Posted November 5, 2009 was reading your reply there again was wondering did you replace your pump as well and did you do anything else to your disco thanks. No - just a fuel pump replacement. My garage did warn against not using a Land Rover original part (and we used a proper Land Rover part). Apparently some of the "pattern" parts (i.e. non-land rover...say Britpart/unipart for instance) are known to be carp. Just wondered if it was worth going in again, and making sure all is OK with your original work... Quote Link to comment Share on other sites More sharing options...
