Ashy Posted November 2, 2009 Share Posted November 2, 2009 We have a 300tdi N reg and recently we have been having an intermittent problem with it. Whilst driving the vehicle loses power without warning. It lasts for only a few seconds and then comes back to life. It is most unnerving ! No dashboard light come on. No miss fire. The engine doesn't cut out completely. Any clues ? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 3, 2009 Share Posted November 3, 2009 manual or auto? EDC or normal injector pump (normally depends on Q1) also what is N reg - 1996? Quote Link to comment Share on other sites More sharing options...
Ashy Posted November 3, 2009 Author Share Posted November 3, 2009 manual or auto? EDC or normal injector pump (normally depends on Q1) also what is N reg - 1996? Hi BogMonster N reg. is first registered 31 12 1995 It is a manual gearbox. Not sure what you mean - EDC or normal injector pump or QI.[ I'm only a woman - small one at that !] Ashy. Quote Link to comment Share on other sites More sharing options...
Jiminy Cricket Posted November 4, 2009 Share Posted November 4, 2009 Hi Ashy, Bit of a newbie myselfhowever had a similar prob with my 96 110 defender - 300tdi as well. After a service, fuel filter change etc it continued to getworse.....after a trip from Scotland to wilts pulling a trailer itgot critical. Although OK on the trip down from Scotland somedays later it became un drivable......turned out to be the fuel liftpump. With the 300 tdi it needs fuel and air and itshould work. If the air filter is clean and youstill have a prob I would look at fuel. Try the water separator(if fitted) near the fuel tank first, then the filter (as in are theyclean and bleed them). Once you have done this and noimprovements try unscrewing the small nut on the fuel filter top,then manually pumping the lift pump (leaver on the underside). If you feel NO resistance try turning the engine over but notstarting, this should make the pump start to work when you pump it. If you still feel no resistance, or after some considerable time nofuel comes out the hole where the nut was in the filter thenyour lift pump is b@%$ed......not expensive and not to hard tochange......fiddle of course! If this is wrong / bad advise -please jump in. Hope this helps you Ashy, Regards Nick:) Quote Link to comment Share on other sites More sharing options...
sheltie50 Posted November 7, 2009 Share Posted November 7, 2009 Have a look at the air filter and work on through the turbo pipes, one could be de-laminating and collapsing under load Quote Link to comment Share on other sites More sharing options...
