rekab69 Posted December 13, 2009 Share Posted December 13, 2009 Hi Guys, The rear wiper on my 1998 110 Td5 has never worked, found out today why that was, the motor unit was sized soild with rust. Looking around for a replacement they are rather expensive compared to a Disco 200tdi, could this unit be made to fit, the shaft looks about the same length, would the "swing" be the same...? Anyone tried this avenue...? cheers DAve.. Quote Link to comment Share on other sites More sharing options...
101sean Posted December 13, 2009 Share Posted December 13, 2009 I had the same problem. A disco one will fit if you swap brackets and do a bit of bodgery on the spindle, pretty straightforward. Quote Link to comment Share on other sites More sharing options...
rekab69 Posted December 13, 2009 Author Share Posted December 13, 2009 I had the same problem. A disco one will fit if you swap brackets and do a bit of bodgery on the spindle, pretty straightforward. Excellent news, thanks Sean... "bodgery's" my middle name.... Quote Link to comment Share on other sites More sharing options...
errol209 Posted December 14, 2009 Share Posted December 14, 2009 I had the same problem. A disco one will fit if you swap brackets and do a bit of bodgery on the spindle, pretty straightforward. The right one off a range rover classic will do too with only a very light sprinkling of bodgery (three thickish M16 washers - they are pretty much identical) Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted December 14, 2009 Share Posted December 14, 2009 I might have one for sale soon enough. Whats the going rate? Quote Link to comment Share on other sites More sharing options...
