TheBeastie Posted December 30, 2009 Share Posted December 30, 2009 I had a cubby box but removed it since I hated the top sitting on a slant (spilt coffee etc). I cannot believe all cubby boxes seem to have parallel edges so follow the slope of the seat box - or am I missing something? I tried to hash together some wooden wedges to level off but they fell apart quite quickly. I now want to refit so I can keep all the cabin cr*p in one place. How do you guys do yours?? Quote Link to comment Share on other sites More sharing options...
mmgemini Posted December 30, 2009 Share Posted December 30, 2009 I don't use the cubby box top to park cups on. That's what the shelf around the gear lever is for.... Quote Link to comment Share on other sites More sharing options...
Ben_J85JTY Posted December 30, 2009 Share Posted December 30, 2009 Most do that - I guess there is no real answer, for example, as you getting it level when the truck is empty or loaded? With or without a trailer attached? If you have a genuine cubby box, do you have the cup holder inserts too? Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted December 30, 2009 Author Share Posted December 30, 2009 Oh well - must just be me! I do not think it is a "proper" cubby box - plywood covered with grey vinyl and a sort of tray at front. My gearbox is covered with a leather thingy. Perhaps I just stop drinking coffee but suspect I would then simply grind to a halt Quote Link to comment Share on other sites More sharing options...
vexedfoxy Posted December 30, 2009 Share Posted December 30, 2009 Well i think it is sloped back slightly to stop things sliding off forwards?? I use the the two cup holders at the front for coffee cups (other beverages are available) then I put my 'phone on top of box in a woolly hat so it does not slide off under the seat which is most anonyning. Quote Link to comment Share on other sites More sharing options...
neildon Posted December 30, 2009 Share Posted December 30, 2009 I fitted a MSS (mobile storage system)cubby box, expensive but good, i havent noticed a slope but it did have a good arrangement of spacers and bolts etc so that may be why. Sometimes expensive is better maybe.....though not often. neil. Quote Link to comment Share on other sites More sharing options...
errol209 Posted December 30, 2009 Share Posted December 30, 2009 I fitted a MSS (mobile storage system)cubby box, expensive but good, i havent noticed a slope but it did have a good arrangement of spacers and bolts etc so that may be why. Sometimes expensive is better maybe.....though not often. neil. Surely, at the angles you can happily dangle a Landy at you'd need some kind of kind of gimball-mounted active levelling system with about 100 degrees of travel both ways (360 on challenge machines, though stopping for coffee upside down mid-stage would be relaxed in the extreme) Sounds like a project for someone with far too much spare time Alternatively, use one of those anti-spill cups for kiddies ? Quote Link to comment Share on other sites More sharing options...
Ben_J85JTY Posted December 30, 2009 Share Posted December 30, 2009 Perhaps a self levelling cubby. A few hydrolic rams and a bt of fab time and you are away! Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted December 30, 2009 Author Share Posted December 30, 2009 OK I surrender I just thought you ought to be able to balance your thermos of coffee and mug on the top. Clearly this is only for wimps so I will put it back as was and re-join the real world! Thanks for the comments which were helpful, actually. Malcy Quote Link to comment Share on other sites More sharing options...
The Homba Posted December 30, 2009 Share Posted December 30, 2009 if your cup is like mine (from tescos) you can just use the handle to hold it to the dash just hook it over. no good if the handle is attaced top and bottom though. cheers Iain Quote Link to comment Share on other sites More sharing options...
mmgemini Posted December 30, 2009 Share Posted December 30, 2009 RAM do a sort of gimball mout for a cup. I have one fitted to my dash. Quote Link to comment Share on other sites More sharing options...
