Brasco Posted January 3, 2010 Share Posted January 3, 2010 Hi, I need to remove the engine from the Disco inorder to replace clutch, flywheel oil seal and timing belt. Is it possible to do it without disturbing the AC system , or do i have to empty the system and remove matrix inorder to be able to remove the engine? thanks Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 3, 2010 Share Posted January 3, 2010 Why not drop the gearbox and do the timing belt in situ? Sounds easier to me.... Quote Link to comment Share on other sites More sharing options...
martinhollings Posted January 3, 2010 Share Posted January 3, 2010 engine out is the a bit easyer but not enough if you need a regas at the end on a 300 you can move the engine forword enought if you take the rad out (but dont no about the air con) but would still do the belt in the car Quote Link to comment Share on other sites More sharing options...
mobyone Posted January 3, 2010 Share Posted January 3, 2010 chock the wheels,remove props, engine crane through the car hang the g/box then lower. you really some need room for the crankshaft oil seal. clutch straight after the oil seal do the timing belt in-situ. it would be easier with engine out, but if you really want it to stay there, do it from the back by removing the g/box. the flywheel will be more difficult with engine still in though. richard Quote Link to comment Share on other sites More sharing options...
