garymorris Posted January 3, 2010 Share Posted January 3, 2010 Hi I'm just about to rebuild a 300 tdi removed from a disco but going in to a defender , the pump has the edc thing on it , i've read Pete Attryde's thread about changing the pump to non edc Soooooooo I need an injector pump ,a friend of mine has a 200 tdi injector pump , Are they the same as a 300 one or not Cheers Gary Quote Link to comment Share on other sites More sharing options...
western Posted January 4, 2010 Share Posted January 4, 2010 IIRC the 200tdi FIP will fit as will the 300FIP onto the 200tdi engine. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 4, 2010 Share Posted January 4, 2010 I expect that they are set up differently though. I know the boost diaphragm in my 200TDI pump hits bottom around 12 psi, so does not add more fuel above that point. I assume the 300TDI pump will be setup for using more boost. Quote Link to comment Share on other sites More sharing options...
LandyLee Posted January 4, 2010 Share Posted January 4, 2010 I didn`t know the 300 run more boost than the 200 , I`ll check the tech manual ,,,, I know the disco and defender 200 tdi pumps are different. The defender one has a lower rev limit ,, Quote Link to comment Share on other sites More sharing options...
western Posted January 4, 2010 Share Posted January 4, 2010 difference in boost pressure is about 0.2bar the 300Tdi runs at 1bar IIRC & 200Tdi Defender at .78 to .80bar Quote Link to comment Share on other sites More sharing options...
garymorris Posted January 5, 2010 Author Share Posted January 5, 2010 IIRC the 200tdi FIP will fit as will the 300FIP onto the 200tdi engine. Cheers Ralph I'll get the inj pump off my mate Quote Link to comment Share on other sites More sharing options...
