RichardAllen Posted January 11, 2010 Share Posted January 11, 2010 As the title says really, I have a 300TDi 90 with a standard battery box. It already has a PC2150 leisure battery in it and the other 'normal' battery is suffering from the weather, so I want to replace it. I got a PC1500 from my factors today, but they provided one with side terminals which is just too wide at 177.5mm. So I am going to take it back tomorrow, but just noticed that a PC1700 at 168.2mm is narrower than a PC1500 without the side terminals at 171.7, Since I am going for a snug fit, has anyone got a PC1700 together with a PC2150 in a standard box ? All help gratefully received. Regards Richard PS I have seen Mike Gemini's thread on rebuilding your box and would like to avoid that option if possible. Quote Link to comment Share on other sites More sharing options...
landy andy. Posted January 11, 2010 Share Posted January 11, 2010 Don't know if this is any use, but is my battery box before fitting pair of odyssey's Quote Link to comment Share on other sites More sharing options...
western Posted January 11, 2010 Share Posted January 11, 2010 2 x PC1700 in my 110, both sat longways & securely strapped down with threaded rod & a alloy strap [homemade] on each attached to the battery box standard J bolt locations, a wooden block under the battery to help it sit level. sorry don't have a photo, tight fit, I had to put the outer battery in first then slide the inner battery in. Quote Link to comment Share on other sites More sharing options...
RichardAllen Posted January 12, 2010 Author Share Posted January 12, 2010 Thanks a million guys Regards Richard Quote Link to comment Share on other sites More sharing options...
RichardAllen Posted January 25, 2010 Author Share Posted January 25, 2010 It seems there are 4 or 5 types of PC1500, and the catalogue my local battery place (JE Clarke in Stroud, very helpful) has is completely different from the Odyssey website. Two wrong PC1500's later I gave up on trying to get the right one, forked out another £30 for the bigger PC1700 which fits snugly but fine alongside a PC2150 in the unmodified battery box, around my VSR charging relay, isolation switch, winch switch, a small fuse box and a lot of wires, leaving a little space to spare for some tools. I have fitted them in 'fore and aft' unlike Landy Andy's setup. Thanks again for the help. Regards Richard Quote Link to comment Share on other sites More sharing options...
