Steve King Posted August 26, 2006 Share Posted August 26, 2006 OK supposing you get the fuel duty issue sorted, what is needed to mix SVO with diesel? Do you have to blend it properly or would it be OK to stick in some diesel, then SVO and top up with diesel and drive over a few road humps?! Quote Link to comment Share on other sites More sharing options...
Guest mr_wuffles Posted August 26, 2006 Share Posted August 26, 2006 I've seen a Td5 running on it had to have new injectors, and fuel pump it was caught just in time...farmers will do anything to save a bit of money eh? Also seen a 200 Tdi that was running on it and the engine was an absolute mess and had new everything the oil turned into black jelly. And a shogun that ended up needing a new engine and fuel pump. If your going to do it do it right! Quote Link to comment Share on other sites More sharing options...
