Who sells tadpole style relief valves for the v8 ?
zim
As per title :) ?
I've found them on ebay - but call me a tight arse - £27 is taking the wee wee i think ! http://cgi.ebay.co.uk/ROVER-V8-ENGINE-OIL-PRESURE-RELIEF-VALVE-UPGRADE-KIT_W0QQitemZ300353760241QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item45ee7aabf1
I've tried real steel, v8 tuner, rpi.... Waiting a return call from JE Developements.
I suppose i could one machined if it came to it, but off the shelf is easier.
Regards
Gordon
  • 1 month later...
I've got a mocal take off plate which replaces the oil pump cover. However due to how the pressure relief valve spring plug screws into it (the housing is shorter so to speak), the spring is under more pressure than a standard pump, coupled with the fact that the tadpole makes the prv slightly longer as well i've decided to make an adjustable relief valve.
Gordon
