jimbobain Posted January 17, 2010 Share Posted January 17, 2010 hi landy dudes, my TD5 was running rough as hell, then it refused to start altogether, so I followed the procedure to clean the oil off the loom and from the ECU. After this she ran a bit better but I think a new Injector Loom is in order. I still think the fuel system is knackered somehow. I still can`t find anywhere that sells the damn Looms. Any ideas folks? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 17, 2010 Share Posted January 17, 2010 Amy dealer ought to be able to get you the injector harness, unless they are on backorder or something. Quote Link to comment Share on other sites More sharing options...
bobtail4x4 Posted January 18, 2010 Share Posted January 18, 2010 They are about £30, not worth trying to clean and seal the old one. Quote Link to comment Share on other sites More sharing options...
MartinK Posted January 18, 2010 Share Posted January 18, 2010 Lots on EBAY for around £30, part number is AMR6103, put that in Google or EBAY and you'll find lots available. Mine was done around 80,000 miles ago, and the problem's not recurred. If you suspect the fuel delivery, maybe a fuel filter change? The fuel pump which sits in the tank can also be a problem, mine failed at around 140000 miles. The Disco lost power (down to 55mph uphill) and was hard to start. Needed a new fuel pump. Was able to drive it to the garage to get ot fitted tho, so didn;t leave me stranded altogether. I did have a look about swapping the pump myself (boot carpet lifted, then through a hatch in the floor - gave up as I was short of time and went to local independant who did it next morning, no problem). Quote Link to comment Share on other sites More sharing options...
