ronancounty Posted February 4, 2010 Share Posted February 4, 2010 Hi. I recently put a disco 200tdi in a 86 ninty, I Dont have or want power steering on the ninty, but because i needed the power steering pump to run the alternater belt from i want to know " will running the pump without ps fluid cause the bearings to fail .? Quote Link to comment Share on other sites More sharing options...
markyboy Posted February 4, 2010 Share Posted February 4, 2010 Hi. I recently put a disco 200tdi in a 86 ninty, I Dont have or want power steering on the ninty, but because i needed the power steering pump to run the alternater belt from i want to know " will running the pump without ps fluid cause the bearings to fail .? In a word..... yes! The pump bearings are lubricated by the PAS fluid, no fluid = no lubrication = no bearings. It should be possible to get a smaller belt if you take the pump off. HTH Mark. Quote Link to comment Share on other sites More sharing options...
JST Posted February 4, 2010 Share Posted February 4, 2010 or connect the inlets and outlets with a res? Quote Link to comment Share on other sites More sharing options...
western Posted February 4, 2010 Share Posted February 4, 2010 remove the PAS pump from the combined bracket, it should just be secured by 3 or 4 bolts to the bracket. Quote Link to comment Share on other sites More sharing options...
ronancounty Posted February 5, 2010 Author Share Posted February 5, 2010 The thing ,is the alternator is run from the pas pump on a seperate belt and is not alined with the water pump/crank pully ,and so i need the double pully to transfer drive to alternator.! Quote Link to comment Share on other sites More sharing options...
western Posted February 5, 2010 Share Posted February 5, 2010 might be easier to fit the full PAS system then. Quote Link to comment Share on other sites More sharing options...
