keithjh Posted February 11, 2010 Share Posted February 11, 2010 Hi All, Is this type of alloy suitable for a 110, am totally confused as usual been told yes been told no http://i7.photobucket.com/albums/y260/keithjh/140.jpg Quote Link to comment Share on other sites More sharing options...
sgnas Posted February 11, 2010 Share Posted February 11, 2010 No, that is from a Disco1. ONLY OEM alloys for a 110 are Deep Dish or Boost. Quote Link to comment Share on other sites More sharing options...
Andrew Chua Posted February 11, 2010 Share Posted February 11, 2010 a 110 will need the boost alloy rims. the disco1 rims will not do as the load rating on the rear is higher than the spec. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 11, 2010 Share Posted February 11, 2010 Not sure how old your 110 is either, if it has drum brakes you will also need spacers or shims to fit even boost alloys as you will not be able to fit the center caps without them. Jason. Quote Link to comment Share on other sites More sharing options...
Dinkydave Posted February 11, 2010 Share Posted February 11, 2010 I've got Compomotive alloys on drums mine. You can get them from Devon 4x4 Quote Link to comment Share on other sites More sharing options...
BogMonster Posted February 12, 2010 Share Posted February 12, 2010 No, that is from a Disco1. ONLY OEM alloys for a 110 are Deep Dish or Boost. Correct. Some of us live dangerously though Quote Link to comment Share on other sites More sharing options...
