CountryGent Posted February 17, 2010 Share Posted February 17, 2010 Hi as part of my 110 conversion I am replacing the clutch master cylinder how ever the pipe that joins the master and slave cylinders (goes across from the master on the f/s to n/s wing and down to the slave) the union joint is seized despite my best efforts to free it. As a result the nut is rounded and to get the master cylinder off I have had to cut off the pipe. As a result I need to replace the pipe as well. Does any one have the part number as I would like to get a genuine LR part Thanks Quote Link to comment Share on other sites More sharing options...
SiWhite Posted February 17, 2010 Share Posted February 17, 2010 If you're passing Lambourn or J13 M4 I have a spare one that came with my 110 project..... It is from a TD5 spec vehicle but I can't imagine that they've changed that much? Quote Link to comment Share on other sites More sharing options...
western Posted February 17, 2010 Share Posted February 17, 2010 threads might have changed from imperial to metric. for a 110 n/a diesel you need pipe NRC8330 http://www.lrseries.com/shop/product/listing/14379/NRC8330-CLUTCH-PIPE-SOLID.html?search=NRC8330&page=1 Quote Link to comment Share on other sites More sharing options...
CountryGent Posted February 17, 2010 Author Share Posted February 17, 2010 If you're passing Lambourn or J13 M4 I have a spare one that came with my 110 project..... It is from a TD5 spec vehicle but I can't imagine that they've changed that much? Fab PM sent. Quote Link to comment Share on other sites More sharing options...
CountryGent Posted February 17, 2010 Author Share Posted February 17, 2010 threads might have changed from imperial to metric. for a 110 n/a diesel you need pipe NRC8330 http://www.lrseries....=NRC8330&page=1 Thanks for the part number - I'll go the SiWhite route and see how it goes. Hopefully it will be a match!! Cheers Quote Link to comment Share on other sites More sharing options...
western Posted February 17, 2010 Share Posted February 17, 2010 happy to help, hope the one Si has is a good fit. Quote Link to comment Share on other sites More sharing options...
CountryGent Posted February 20, 2010 Author Share Posted February 20, 2010 happy to help, hope the one Si has is a good fit. Hi, Just to let you know it is a lovely pipe BUT NOT a fit - at least for my '85 110. So NRC8330 it is then. Any one with a TD5 need a pipe? Quote Link to comment Share on other sites More sharing options...
