Jake Lloyd Posted February 28, 2010 Share Posted February 28, 2010 Defender 2002 110. Front interia light. There's 3 wires. red, white and yellow. Which is which? Help Quote Link to comment Share on other sites More sharing options...
western Posted February 28, 2010 Share Posted February 28, 2010 What you need is this 2002 wiring diagrams Td5 & last of the 300Tdi's. those colours you have are not factory wiring, the front interior light has these purple/brown trace from fusebox to bulb one side of the slide switch to earth Black wire other side of switch to Purple/white trace to alarm ecu or door switches [purple/blue trace] see diagram section 44 pages 72/73 in link above. Quote Link to comment Share on other sites More sharing options...
Jake Lloyd Posted February 28, 2010 Author Share Posted February 28, 2010 I have a 300 Tdi 110 that i'm fitting a Outback roof console too. The console has the red, yellow white wiring fitted to it. The intructions say to put them to the red, yellow ane white. Which is proving to be a pain, being as i have a purple, blue-purple and black ! Back to the car and some more head scratching Cheers Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 28, 2010 Share Posted February 28, 2010 Ralph is right. Those are not Land Rover wiring colours. Maybe riceburner ones. Purple is live through a fuse IIRC. Purple/ Black goes to door switches and black is earth. Here is a full list of Lucas colours http://www.vord.net/cars/wiring/colours.php A test lamp will soon sort out what goes where HTH Quote Link to comment Share on other sites More sharing options...
western Posted February 28, 2010 Share Posted February 28, 2010 the diagram below is for the 300Tdi [without Td5 type instruments] thought it might help you identify the wires easier. Quote Link to comment Share on other sites More sharing options...
