STEFF 110 Posted September 13, 2013 Share Posted September 13, 2013 hi there guys. wow. you guys rock. so much help. this is where I am right now. checked the small rubber hose checked the expansion bottle checked the fuel cooler checked for water in the rh engine mount head had pressure test done and cleaned checked radiator as best as possible and all looks good there. rubber hoses all round. so far no leaks found. disconnected the heater matrix and still waiting to see if it uses water. haven't done enough kilometres yet. the only thing i have changed is im running anti freeze/ coolant now to try and found the leak better. the only thing i see is that the weep hole has a damp stain to it. don't see any drip or stain on motor further down. can this be the problem? many thanks for the help guys regards steff Quote Link to comment Share on other sites More sharing options...
Rangy35 Posted September 13, 2013 Share Posted September 13, 2013 I would not worry yet, keep a eye on it. Quote Link to comment Share on other sites More sharing options...
STEFF 110 Posted September 16, 2013 Share Posted September 16, 2013 hi there . i hope people are still viewing this. next thing discovered. smell on anti freeze. not sure if its out of the heater matrix, as i have disconnected it. but that is my finding. any advice? Quote Link to comment Share on other sites More sharing options...
Rangy35 Posted September 17, 2013 Share Posted September 17, 2013 Are you still losing coolant after all the new parts been fitted Quote Link to comment Share on other sites More sharing options...
STEFF 110 Posted September 17, 2013 Share Posted September 17, 2013 no. it has been an on going water/coolant loss. why you ask? Quote Link to comment Share on other sites More sharing options...
