keithjh Posted May 1, 2006 Share Posted May 1, 2006 Hi All, Am in the process of converting a ex mil 2.5N/A 110 into a 300 TDI Auto, engine box etc from a Disco. Anyway engine box in the 110 no problems rad etc fitted plus hoses, was hoping too use the air filter from the disco but no space even after removing washer bottle from n/s wing. Having justy measured up i can get the air filter housing in from a 200 TDi pretty easily, is there any reason why this cant be used?, or at lezast whats the easiest way of solving the air filter problem? I have totally removed the EGR from the manifold and blanked it of at the manifold to gain more space. i know several people have done this and the answer is probably straightforward its just me have a lot of "senior moments" recently or at least thats what the wife says!! Regards Keith Quote Link to comment Share on other sites More sharing options...
western Posted May 1, 2006 Share Posted May 1, 2006 Can't see why you shouldn't, I note you have a 200TDi for guidance so getting it in the right place shouldn't be a problem. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 1, 2006 Share Posted May 1, 2006 Yes you can Keith, I have Mo Quote Link to comment Share on other sites More sharing options...
keithjh Posted May 1, 2006 Author Share Posted May 1, 2006 Yes you can Keith, I have Mo Thanking you, i new someone on here would have done it, now to find the 200TDi filter box, is it in the garage?, shed, or just put somewhere safe? or is the bl--dy wife using it as a plantpot?. Regards Keith Quote Link to comment Share on other sites More sharing options...
