tweetyduck Posted March 8, 2010 Share Posted March 8, 2010 does this have a direct replacement? Got confused with all the, this bolt and that bolt. Which one is this? Thanks N Quote Link to comment Share on other sites More sharing options...
white90 Posted March 8, 2010 Share Posted March 8, 2010 4 bolt it refers to the number of bolts that hold the top on. and yes readily available from any L/R parts supplier Adwest will sell you an as new one . Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted March 8, 2010 Author Share Posted March 8, 2010 thanks. 4 bolt = 4 bolts...simples. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted March 9, 2010 Author Share Posted March 9, 2010 any idea how much they are ? Are they just like new ? Thanks Quote Link to comment Share on other sites More sharing options...
white90 Posted March 9, 2010 Share Posted March 9, 2010 Adwest ones are as good as New! what's wrong with yours? I see no massive leaks etc No point in replacing parts that are working just fine. Quote Link to comment Share on other sites More sharing options...
western Posted March 9, 2010 Share Posted March 9, 2010 existing box looks nice & dry, can't see any trace of leaks, as Tony says if it works OK. leave it in place. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted March 9, 2010 Author Share Posted March 9, 2010 right at the top of the drop arm theres a nice deposit of black shiny gunk. Advice appreciated. What to do? Quote Link to comment Share on other sites More sharing options...
western Posted March 9, 2010 Share Posted March 9, 2010 I'd call that a slight weep, not a large leak by any means, you could change the seal above the drop arm. if you wipe that 'shiney gunk' off how long for it to reappear as a damp area ? when warmed up & in use is there ant leakage apparent ? Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted March 9, 2010 Author Share Posted March 9, 2010 thanks. I'll do that. report back soon. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted March 10, 2010 Author Share Posted March 10, 2010 OK so i cleaned it up. Is it possible to replace that lower seal if needed. I can see it now right where the pin goes into the PAS box, it sticks out about 2mm proud of the casing. Will see if it leaks in the next few days. The seal actually looked OK but thats no sign its doing its job. Quote Link to comment Share on other sites More sharing options...
western Posted March 10, 2010 Share Posted March 10, 2010 110 parts book shows a seal kit STC1042 for the lower end of the shaft, has inner & outer seal, washer & circlip. inner seal was part 608066 outer seal was RTC6110 Quote Link to comment Share on other sites More sharing options...
