henry Posted March 18, 2010 Share Posted March 18, 2010 Hi Im back again with my Land Rover 90 with 200TDi Disco Engine. This time my starter motor is not functioning at all. A few days ago tried to turn the engine over and only heard the starter motor solenoid clicking. I assumed this would be a flat battery because I had heard the exact same thing before when I have had flat batterys. I took the battery inside to trickle charge over night and have just put back in the land rover. Even after charging the battery I am still only hearing the starter motor solenoid!! I have checked: 1. Battery voltage = 13v + 2. Earth lead from starter motor to Engine block 3. Earth Lead from engine block to chassey When I touched the +ve terminal terminal to the solenoid it was very hot! so I disconnected the battery quickly... I do hope that the starter motor has not given up. It was new february 2009. Im going to continue to work out whats wrong, but any help is greatly appreciated H Quote Link to comment Share on other sites More sharing options...
western Posted March 18, 2010 Share Posted March 18, 2010 sounds like the soleniod is stuck, motor off & test on floor with jump leads to see if it works. Quote Link to comment Share on other sites More sharing options...
henry Posted March 18, 2010 Author Share Posted March 18, 2010 So if solenoid is stuck can it be unstuck with a gentle hammer? Quote Link to comment Share on other sites More sharing options...
western Posted March 18, 2010 Share Posted March 18, 2010 yes, but it'll only be a very temporary fix, another starter would be better, but not a Prestolite unit. Quote Link to comment Share on other sites More sharing options...
henry Posted March 18, 2010 Author Share Posted March 18, 2010 Thank you Western. It has started raining so im going to remove it tomorrow morning. I was hoping to be able to do something without removing it because last time I had to remove the downpipe. Its a bit annoying seeing that the motor is only 1 year old. Ha oh well. Quote Link to comment Share on other sites More sharing options...
henry Posted March 19, 2010 Author Share Posted March 19, 2010 Good Morning I have taken out the Starter Motor and tested straight to the battery and there was nothing except a little sparking from the -ve terminal when I attached the last jump lead. I think the motor has done something horrid to itself. The best thing to is replace rather than repair i expect. Im at University in Portsmouth, but I have a good spare at home in Norfolk, so I dont really want to have to buy an expensive replacement. Does anybody know of any cheap units good enough to get me home? Hopefully near Portsmouth. H Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 19, 2010 Share Posted March 19, 2010 Jump directly to the main starter - rather than the solenoid. If the motor works ok, then you only need to replace the solenoid (about £30). Les. Quote Link to comment Share on other sites More sharing options...
henry Posted March 19, 2010 Author Share Posted March 19, 2010 Earlier I connected straight to the starter bypassing the solenoid with absolutely no results. I have just connected to the solenoid and used a 3rd Jump lead to trigger the solenoid. This time the gear fired out but there was no rotation from the motor. All I have done is use the solenoid to trigger the gear arm. So it is still the same problem really. H Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 19, 2010 Share Posted March 19, 2010 Sounds like a new starter then. You can partially strip them down, but parts are difficult to get. Usually - the main motor brushes stick in their guides (there are four of them). Les. Quote Link to comment Share on other sites More sharing options...
