disco_al Posted March 30, 2010 Share Posted March 30, 2010 Now I suspect that this is quite a commom problem with Disco's. The lower hinge on my 300 has got quite a lot of play in it, and as such is causing the rear door to drop and catch on the bumper. I have a new hinge to go on which will hopefully cure this problem, so, can anyone suggest the best way to approach replacing the hinge? Quote Link to comment Share on other sites More sharing options...
pw8757 Posted March 30, 2010 Share Posted March 30, 2010 I've had to do this on mine. Lessons learnt: It is possible to do it on your own Replacing both saves having to strip the door out again a few months later (Although you would not take them both off at once!!) It is a REALLY GOOD IDEA to take the spare wheel off before you start. (I am prepared to acknowledge learning that the hard way! ) Also - if you are on your own, a jack with a piece of 2x2 cut as a prop will be handy Quote Link to comment Share on other sites More sharing options...
disco_al Posted March 30, 2010 Author Share Posted March 30, 2010 with the price of the lower one, i think i'll stick to just that one for now cheers for the advice. i may take the easy route then, and use a ratchet strap around the roof beam of a friends barn to support it. Quote Link to comment Share on other sites More sharing options...
maxtherotti Posted March 31, 2010 Share Posted March 31, 2010 must be hinge time as i just did mine too!!! (got a pair of new in packs off ebay for £10.55 delivered ) defo take the spare off!!!!!!!! get new proper rivits for the end plate and a big a$$ rivit gun to do them with a second pait of hands is usefull rob Quote Link to comment Share on other sites More sharing options...
