renault4 Posted April 7, 2010 Share Posted April 7, 2010 whilst staring into the murky deapths of my 2.5 TD 110 I notice that with the engine running, the crankshaft pully appears to "wobble" any ideas? Quote Link to comment Share on other sites More sharing options...
western Posted April 7, 2010 Share Posted April 7, 2010 if it's the thin metal pulley that the belts run in is bolted to the heavy crankshaft damper [the thick bit] check the 4 bolts are tight. Quote Link to comment Share on other sites More sharing options...
rovernut Posted April 7, 2010 Share Posted April 7, 2010 whilst staring into the murky deapths of my 2.5 TD 110 I notice that with the engine running, the crankshaft pully appears to "wobble" any ideas? Some years ago I had the pulley work loose on a 2.5 TD 90. The bolt had worked loose and the pulley destroyed the end of the crank. I built the end of the shaft up with plastic metal, fitted a new key,pulley and bolt. This repair was still holding some five years later when I sold the 90 on. At the time I seem to recall that there was a problem with 2.5 TD crankshaft end bolts working loose. Quote Link to comment Share on other sites More sharing options...
reb78 Posted April 7, 2010 Share Posted April 7, 2010 At the time I seem to recall that there was a problem with 2.5 TD crankshaft end bolts working loose. My experience with this about 3 years ago was the garage changing the timing belt not torquing the crank bolt up properly! Got it back and could practically undo it with my fingers. Have not paid a garage for anything other than MOTs since. Worth checking the crank bolt is tight, but what Ralph suggests is hopefully the cause. Quote Link to comment Share on other sites More sharing options...
