Drizz Posted April 11, 2010 Share Posted April 11, 2010 Are there rebuild kits available or do you have to buy all the individual parts? Im going through microcat and theres lots of parts lol so buying a kit would be easier. Any recommendations? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 11, 2010 Share Posted April 11, 2010 Pinion and ring gear should be a matching set. The only other thing is the sun gears, which come as a set - 4 x sun gears, pin, 2 x circlips. Bearings are seperate, but 4 of them - Pinion outer bearing, pinion inner bearing, carrier bearings x 2. Rebuilding a diff perfectly is very time consuming, but doing it by 'feel' gets it pretty good. Mix-'n'-match of the gearing is not so good however. Les. Quote Link to comment Share on other sites More sharing options...
Drizz Posted April 11, 2010 Author Share Posted April 11, 2010 I should have explained better. I meant everything apart from the diff's as im going arb and ashcroft shafts/CVs, so i mean spheres, seals and associated parts Cheers Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted April 11, 2010 Share Posted April 11, 2010 There's a Britpart kit for the swivels, about 70 notes + VAT from Paddocks. Bear in mind that for some strange reason it does not include the gaskets for the lower swivel pins (FTC3647). I've just comprehensively re-built my front axle, including replacing all seals as well as fitting new pistons and seals in the calipers (although I have not changed the half shafts). I've been keeping a spreadsheet with a list of what I have spent on my project, which includes a list of all the part numbers. If you'd care to PM me an e-mail address I'll send you the list of parts for the axle. Nick. Quote Link to comment Share on other sites More sharing options...
Drizz Posted April 11, 2010 Author Share Posted April 11, 2010 Great ill pm now Quote Link to comment Share on other sites More sharing options...
