Halfords 2.5 ton car ramps question.
kingdong2
Hi guys
a quick question, will 2 x halfords 2.5 ton car ramps hold a disco 2 safely, the idea is i want to paint the chassis of the disco and at a later date i want to replace the tranny oil and filter when the mileage is due and the car needs to be level to do this.
graham
____________________
03 d2 td5 auto e.s.
97 d1 300 tdi man.
i think if each is rated at 2.5 tons then 4 should hold 10 tons between them.
wouldn't like to put that much on them though.
i await correction now though :lol:
You shouldn't just multiply safe working loads up: 2.5 tonnes for one, 3.75 tonnes for two, 7.5 for four. However, they will probably have a factor of safety of nearly 2, which means four might collapse at anything between 7.5 and 15 tonnes ... only 3 to 7 times the weight of the car :D ...
