pugrocket Posted April 21, 2010 Share Posted April 21, 2010 Hey guys. I have started to install a new complete exhaust system to my 90. I have fitted the down pipe and then the mid pipe. between the 2 I have put an olive connection. But when it comes to fitting the mid silencer and back box, am I supposed to put the olive rings between these connections or not, only the connection between the mid silencer/mid pipe and mid silencer/back box, dont seem to go together. Any help will be much appreciated Thanks Quote Link to comment Share on other sites More sharing options...
jbs Posted April 21, 2010 Share Posted April 21, 2010 Engine type would be good to get a decent answer Quote Link to comment Share on other sites More sharing options...
pugrocket Posted April 21, 2010 Author Share Posted April 21, 2010 sorry, its a 2.5 td Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 22, 2010 Share Posted April 22, 2010 1st joint (downpipe to first section) is sealing ring. Next joint should be 3 nut/bolt flange, and the pipe ends should be shaped to fit (use a small amount of Fire Gum though). Les. Quote Link to comment Share on other sites More sharing options...
jbs Posted April 22, 2010 Share Posted April 22, 2010 See told you Quote Link to comment Share on other sites More sharing options...
pugrocket Posted April 22, 2010 Author Share Posted April 22, 2010 1st joint (downpipe to first section) is sealing ring. Next joint should be 3 nut/bolt flange, and the pipe ends should be shaped to fit (use a small amount of Fire Gum though). Les. Cheers I obviously have the wrong piece as all the joins are the sane so I'm gonna go and get the right one today and finally get it finished Quote Link to comment Share on other sites More sharing options...
shanghai1979 Posted April 22, 2010 Share Posted April 22, 2010 I fitted a new exhaust system to my 200Tdi. Was horrid getting everything to line up. Bought it from Padocks. Very cheap though but still was a B*tch to install. Needed a lot of pulling and grunting lol. One tip change the rubber mounts. Padocks don't do them though. I got mine on ebay. Makes the 200Tdi very quiet and smooth. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted April 22, 2010 Share Posted April 22, 2010 I fitted a new exhaust system to my 200Tdi. Was horrid getting everything to line up. Bought it from Padocks. Very cheap though but still was a B*tch to install. Needed a lot of pulling and grunting lol. One tip change the rubber mounts. Padocks don't do them though. I got mine on ebay. Makes the 200Tdi very quiet and smooth. Must have been a 541tpart one. Sounds just like the experience I had fitting one of their 3.9 RRC systems. I even had to break out the grinder and welder to make it fit Quote Link to comment Share on other sites More sharing options...
pugrocket Posted April 22, 2010 Author Share Posted April 22, 2010 I went paddocks today and turned out I needed 2 more olive connectors so I'll be fitting the rest tonight but the mid pipe was a nightmare Quote Link to comment Share on other sites More sharing options...
