trickydicky Posted April 23, 2010 Share Posted April 23, 2010 just drove home with no clutch. while driving home the clutch went to the floor suddenly and then there was just nothing. the clutch has done about 5000 miles so i dont think its the plate or i wouldnt be able to drive it . has anybody got any idea whats going on? P.S its a 2.5td if that makes a difference Quote Link to comment Share on other sites More sharing options...
sean f Posted April 23, 2010 Share Posted April 23, 2010 Couple of things come to mind. First have you had a hydraulic failure, check the level in the reservoir, if this is the case its a relatively cheap fix. Try topping up the fluid but you would probable have to change the master and slave cylinder, not to expensive or difficult. Second thing is it could be the clutch fork holeing through where it pivots in the bell housing. Cheap for parts but involves the box coming out (or engine) to change it. Any one who knows anything about landrovers always changes this with the clutch as they wear quite badly but if your clutch was done by some one who does know about this then they could have left the old one in. Quote Link to comment Share on other sites More sharing options...
jbs Posted April 23, 2010 Share Posted April 23, 2010 If your clutch fork has gone it would be a good idea to reinforce the fork if you need to change it and if you buy one thats not already reinforced you can weld a strip of metal across where the ball fit's behind the fork, this is the guide you can follow http://forums.lr4x4.com/index.php?showtopic=5010 to see what damage to the fork has been done And here if you scroll down about 3/4 the way down the page you'll find what I'm trying to describe http://forums.lr4x4.com/index.php?showtopic=18171 HTH John Quote Link to comment Share on other sites More sharing options...
trickydicky Posted April 23, 2010 Author Share Posted April 23, 2010 i have a look tomorow but all the hydrolics are new so its looking like its the fork then . ill let you know over the weekend how i get on. Quote Link to comment Share on other sites More sharing options...
trickydicky Posted April 25, 2010 Author Share Posted April 25, 2010 i took the gearbox out today what a mission that is on your own . it was the clutch arm so i welded it back up and reinforced it with a steel plate it all seems fine now . im just off to put the seats and floor back and thats me done thanks guys. Quote Link to comment Share on other sites More sharing options...
