love2learn Posted April 26, 2010 Share Posted April 26, 2010 im getting a junk-junk-junk when i turn sharp corners especially in these multi story carpark helter skelter places. any ideas and is it serious? thanx in advance Quote Link to comment Share on other sites More sharing options...
Les Brock Posted April 26, 2010 Share Posted April 26, 2010 I'd say the chances are one of your CV's is on its way out ! Quote Link to comment Share on other sites More sharing options...
errol209 Posted April 26, 2010 Share Posted April 26, 2010 I'd say the chances are one of your CV's is on its way out ! Or, just possibly mind, that the tyre lugs are catching on the radius arms at full lock? Otherwise as Les says Quote Link to comment Share on other sites More sharing options...
love2learn Posted April 26, 2010 Author Share Posted April 26, 2010 which cv is the most likely candicate? should i just do both and whatll the parts be do ya think? and can i do it meself? AND is there a step by step available? AND thanx Quote Link to comment Share on other sites More sharing options...
errol209 Posted April 26, 2010 Share Posted April 26, 2010 which cv is the most likely candicate? No way to tell easily, I suppose if you jacked each wheel up seperately and turned it by hand on full lock you might hear a difference. should i just do both and whatll the parts be do ya think? The parts'll be new . About £35 each side? and can i do it meself? Yes. AND is there a step by step available? There isn't an obvious one in the technical archive, but there are links to the workshop manuals and a search never hurts. AND thanx My pleasure. Quote Link to comment Share on other sites More sharing options...
love2learn Posted April 26, 2010 Author Share Posted April 26, 2010 what tools will i need for this job? and does it come all fitted together or in a box with a dozen seperate parts? i cant find this job im my haynes manual either? ive got the 1983 to 95 (upto n reg version)? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 26, 2010 Share Posted April 26, 2010 CVs generally make a clicking noise on full lock when they're on the way out. Could be the tyres rubbing on the radius arms as suggested above. Mine does both If you do need to change the CV(s) then it's a nuts and bolts job really, the wheel, hub and stub axle need to come off, so a good socket set with spanners etc. will be required as well as some others such as a hammer and the like. Have a look at this thread. It isn't specifically what you (might) need to do but it does cover what's required to do so (and more). Also will give you an understanding of how it's all built down there. http://forums.lr4x4.com/index.php?showtopic=5601 Quote Link to comment Share on other sites More sharing options...
errol209 Posted April 26, 2010 Share Posted April 26, 2010 what tools will i need for this job? and does it come all fitted together or in a box with a dozen seperate parts? i cant find this job im my haynes manual either? ive got the 1983 to 95 (upto n reg version)? Some or all of your questions answered - pdf page 50 onwards. (from the link in our Technical Archive) I think it will probably come in bits ... Quote Link to comment Share on other sites More sharing options...
