TheHarv Posted May 10, 2010 Share Posted May 10, 2010 I posted a while back about mucky black clutch fluid - based on advice here I replaced slave, master AND flex pipe (to be sure) with new OEM parts (AP slave and Girling master). The only bits I didn't replace were the hard line on the bulkhead (flushed it well though) and the slave push rod (because the new one I got wasn't the right length). I cleaned up the old rod as well as I could but it was still somewhat rough / pitted. Well it's gone and done the same thing within a few thousand km. I pulled the slave off again at the weekend and the boot appeared to have separated from the end of the cylinder - SO my theory is the rough push rod dragged the boot off and allowed crud to get in and work its way behind the seal - does that sound plausible? Q2: when examining the guts of the slave, there is a groove on the piston that was packed full of the same black muck that appeared to have got into the fluid - is there supposed to be a secondary seal of some sort? is that what disintegrated (see all the black muck on the paper towel) or is it all just road grime? Q3: I polished up the bore with 1000 grit paper - since it's basically new I was not planning on replacing the seal (especially as the only seal kit I have on hand is Britpart...) - good idea? bad idea? Q4: does anyone know the correct P/N for the slave push rod for a 2.5N/A with short bellhousing R380? Thanks once again Quote Link to comment Share on other sites More sharing options...
western Posted May 10, 2010 Share Posted May 10, 2010 pushrod for 4 cylinder engines & short R380 is FRC4229, it's not cheap though here recently replaced mine as I thought it was wrong, but turned out to be correct, road grit can't get into it very easily as the rod is inside a virtually enclosed space, could be dust from clutch wear & moisture or old seals make the fliud turn black too. Quote Link to comment Share on other sites More sharing options...
TheHarv Posted May 10, 2010 Author Share Posted May 10, 2010 eek thanks - precision cut by the tears of solihull unicorns no doubt I hadn't considered clutch wear material - I did end up taking a bit of a dip with the wading plug out but other than that I don't know where it all could have come from Quote Link to comment Share on other sites More sharing options...
