Adam001 Posted May 20, 2010 Share Posted May 20, 2010 Hi, I have a 1991 Discovery transfer box fitted to my Defender, with the designation 28D. From my knowledge this means it is fitted with the 28tooth input gear and it suffix D. Is this correct? The input gear is not crossdrilled, so does anyone know the part number for the 28 tooth cross drilled gear? regards Adam Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted May 20, 2010 Share Posted May 20, 2010 my 1993 disco transfer box was still 26 tooth Quote Link to comment Share on other sites More sharing options...
jad Posted May 20, 2010 Share Posted May 20, 2010 when i got my cross drilled one from ashcroft i just told them the serial number of the box. ask them to push the bearings on if you get it from them. had to get a lift back after i opened the box Quote Link to comment Share on other sites More sharing options...
Adam001 Posted May 20, 2010 Author Share Posted May 20, 2010 Ah ok I called them and they said I needed ftc5089 which is the crossdrilled 26 tooth one Going to order one tomorrow, and good call on getting them to push the bearings on, i'll get them to do that Adam Quote Link to comment Share on other sites More sharing options...
