TheBeastie Posted May 23, 2010 Share Posted May 23, 2010 Does anyone have any experience of fitting those rotating roof ventilators to back of a 90 hard top? Looking for ways of making life more comfortable for the dog when we are out no that we finally seem to have a summer coming our way?? Thanks Malcy Quote Link to comment Share on other sites More sharing options...
western Posted May 23, 2010 Share Posted May 23, 2010 should be fairly easy just a hole for the vent shaft & air duct & fixing holes, can't be that hard to fit. Quote Link to comment Share on other sites More sharing options...
pinny Posted May 23, 2010 Share Posted May 23, 2010 i fitted one in a transit roof i think it was a 3 inch hole drilled a hole and cut it out with a jigsaw there is three small boltholes iirc quite an easy installation chris Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted May 23, 2010 Author Share Posted May 23, 2010 OK, thanks And do they make much of a difference? OK, I know cannot leave him in sun etc but would it help give a circulation of fresh air? Quote Link to comment Share on other sites More sharing options...
pinny Posted May 24, 2010 Share Posted May 24, 2010 yes and no it oviously works better when your moving as its spinning but failing that option go for one of the electric powered roof vents thay work either direction suck/blow have a look at some pictures of the police dog vans most have these fitted,chris. Quote Link to comment Share on other sites More sharing options...
western Posted May 24, 2010 Share Posted May 24, 2010 yes and no it oviously works better when your moving as its spinning but failing that option go for one of the electric powered roof vents thay work either direction suck/blow have a look at some pictures of the police dog vans most have these fitted,chris. IIRC there is a solar powered ventilator available it may solve the no air flow when the vehicle is parked. for example more roof vent links here Quote Link to comment Share on other sites More sharing options...
ajh Posted May 25, 2010 Share Posted May 25, 2010 Or fit a safari roof, the double layer and vents cause a heat-driven siphon effect. Quote Link to comment Share on other sites More sharing options...
Adam001 Posted May 25, 2010 Share Posted May 25, 2010 I have a solar ventilator on my 110, lasted about 5 years before it died, worked quite well with the dog in the back Quote Link to comment Share on other sites More sharing options...
