dixe Posted May 27, 2010 Share Posted May 27, 2010 I have just bought a set of britparts brake adjusters and when I fitted them as per the instructions. I found that they do not adjust the brake shoes. I have a long wheel base series III. According to the instructions the spring should go outside of the backing plate but then the bolt is not long enough so the adjuster does not touch the pin to adjust the brake. any advice would be appreciated. Dixe Quote Link to comment Share on other sites More sharing options...
reb78 Posted May 27, 2010 Share Posted May 27, 2010 I've got a set like this for my 110 although the series bits were in there too. A load of the washers mentioned in the instructions were missing in mine. Might be worth chasing up with the supplier to check the correct parts have been supplied. Quote Link to comment Share on other sites More sharing options...
jbs Posted May 27, 2010 Share Posted May 27, 2010 Britpart strikes again!! if you can send them back and get hold of some either made by bearmach or even allmakes it'll do what it says then Quote Link to comment Share on other sites More sharing options...
