gilloverland Posted May 29, 2010 Share Posted May 29, 2010 I'm currently restoring an early 1984 CSW. It has the two-piece middle doors with alluminium door tops and lift up outer handle door bottoms, the handles on the inside of the door are like the later version and operate via little rods. I'm after the plastic 'U' shaped trim pieces that surround the door handle (2 pieces, a top and bottom that slide together)and help hold the door card in place. I either need the part numbers from an ealy 110 catalogue or contact details for a supplier/breaker who has some. Any help gratley apprechiated... Quote Link to comment Share on other sites More sharing options...
western Posted May 29, 2010 Share Posted May 29, 2010 I think the bits you want are item 10 on the botttom diagram Quote Link to comment Share on other sites More sharing options...
gilloverland Posted May 29, 2010 Author Share Posted May 29, 2010 Wow, that was fast, many thanks Ralph. The doors in the diagram are different (wind up windows) but I'm pretty sure part 10 IS the part I'm after, Thankyou Quote Link to comment Share on other sites More sharing options...
western Posted May 29, 2010 Share Posted May 29, 2010 the other diagram for the split/sliding window doors doesn't show any trim U shaped pieces around that handle. BUT just found the split door trim pieces, they have the same parts number CZA2259L as the wind up window doors. see item 20 on the bottom diagram below if you cannot find any, these handles/trim were used on numerous BL cars of the late 70's/early 80's, such as the Austin Maxi & Morris [Austin in USA] Marina Quote Link to comment Share on other sites More sharing options...
gilloverland Posted May 29, 2010 Author Share Posted May 29, 2010 Cheers, just found out that the part number cza2259, is common accross lots of British Leyland motors. MGB, range rovers etc, just found someone selling a set of 4 for £5 on e**y. Quote Link to comment Share on other sites More sharing options...
western Posted May 29, 2010 Share Posted May 29, 2010 Cheers, just found out that the part number cza2259, is common accross lots of British Leyland motors. MGB, range rovers etc, just found someone selling a set of 4 for £5 on e**y. excellent Quote Link to comment Share on other sites More sharing options...
