Swampdog Posted June 5, 2010 Share Posted June 5, 2010 This is my first post so I'd like to say hello to everybody. I have a 2003 Defender 90 TD5 XS and have the common problem of the Abs/Tc light coming on. The brakes and tc work ok and when I take it to my local independant L/R garage it reads shuttle valve failure. He clears the fault and the lights stay out for up to 6 months and the systems work fine, then bing the're back again I do a few emergency stops and all is working well so back to the garage and switch them off. I was wondering what would be the cheapest option to buy so that I could clear the fault myself. i have looked at the Hawkeye but it is a bit expensive for me to use just for this one fault. Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted June 5, 2010 Share Posted June 5, 2010 Why not try fixing the fault Quote Link to comment Share on other sites More sharing options...
Swampdog Posted June 5, 2010 Author Share Posted June 5, 2010 Why not try fixing the fault The trouble is when he clears the logged fault the shuttle valve is ok A new one is £2,112 + 3hrs labour. A lot to spend when it may or may not be the fault. He thinks it might be sticking momentarily now and again, but it doesn't seem to affect the brake systems at all. Quote Link to comment Share on other sites More sharing options...
popotla Posted June 6, 2010 Share Posted June 6, 2010 Did I read that right? GBP 2,112.00?? That’s one-tenth the cost of a whole new vehicle. Why are we being ripped off? Quote Link to comment Share on other sites More sharing options...
T1G UP Posted June 6, 2010 Share Posted June 6, 2010 i read an article years ago about the cost of a mk3 escort in parts was nearly 4 times what it cost to buy as a whole! i'd continue as you are my friend....then remove the abs when it packs up all together. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 6, 2010 Share Posted June 6, 2010 The trouble is when he clears the logged fault the shuttle valve is ok A new one is £2,112 + 3hrs labour. A lot to spend when it may or may not be the fault. He thinks it might be sticking momentarily now and again, but it doesn't seem to affect the brake systems at all. Where is the sensor mounted? you seem to be able to buy the parts for far less than £2k. http://cgi.ebay.co.uk/Landrover-Defender-abs-pump-/270587528738?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f00460622 Jason. Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted June 6, 2010 Share Posted June 6, 2010 The trouble is when he clears the logged fault the shuttle valve is ok A new one is £2,112 + 3hrs labour. A lot to spend when it may or may not be the fault. He thinks it might be sticking momentarily now and again, but it doesn't seem to affect the brake systems at all. Ok....point taken....but you must be aware that you driving a vehicle with a fault on the braking system puts you in a very tricky situation (should you have an accident)....not saying you will or that anything will go wrong but "IF" it does and the police investigate your car then you are liable. Sorry to be so blunt but the braking system is a vital park of the car. Quote Link to comment Share on other sites More sharing options...
Swampdog Posted June 7, 2010 Author Share Posted June 7, 2010 Did I read that right? GBP 2,112.00?? That’s one-tenth the cost of a whole new vehicle. Why are we being ripped off? I rang my local L/R dealer and I was mistaken with the price it is actually £1850+vat a grand total of £2173.75 and they said it is not repairable Cheers for all the replies. I have bought a Hawkeye diagnostics unit and it is showing no faults at present, but has a historically logged fault showing a bad earth on the ABS shuttle valve. Hopefully this is external and I will be able to trace it. Thanks for the ebay link if I can't get it sorted I may go for this option, they come up quite regularly on there but you dont really know what you're getting and no comebacks. Never had this bother with my old 200tdi I am begining to regret swapping it Quote Link to comment Share on other sites More sharing options...
carlosbeldia Posted June 9, 2010 Share Posted June 9, 2010 The earth problem use to be rust in the bolt or screw under passenger seat, the earth near the one from the ECU. Just unscrew it, some WD40 and tie it again, that must solve your problem. The Wabco unit is serviceable, they sell the shuttle valve around GBP 40, I think. The Wabco unit was quoted sometime ago in GBP 770 from Britcar, LrSeries or something, I cant remember Quote Link to comment Share on other sites More sharing options...
Swampdog Posted June 9, 2010 Author Share Posted June 9, 2010 The earth problem use to be rust in the bolt or screw under passenger seat, the earth near the one from the ECU. Just unscrew it, some WD40 and tie it again, that must solve your problem. The Wabco unit is serviceable, they sell the shuttle valve around GBP 40, I think. The Wabco unit was quoted sometime ago in GBP 770 from Britcar, LrSeries or something, I cant remember Thanks for the advice I'll have a look if that's the problem. I think the ABS unit you refer to is the earlier one,same as on the Disco's the shuttle valve switch is separate and under the unit they are easily changed and cost £38. The Wabco unit on my 2003 Defender 90 td5 xs is all one piece I have spoken to Landrover UK and Wabco they both say it is none servicable and a new one required at over £2,000 a ridiculous price for a little aluminium box I think it must be filled with gold and diamonds Quote Link to comment Share on other sites More sharing options...
