ECU errors not erasing
Do a quick wiring inspection of the loom that goes to the ABS controller from the fusebox, particularly where it passes through any panels etc.
The fuse blew for a reason, it may have been something in the ABS unit, or it may have been a wiring fault. The latter I'd rather find and fix if I'm honest, than have the truck burn to the ground! :P
