19J temperature sender
I'm clearly being very dumb but I'll be damned if I can find the engine temperature gauge sender on my old 19J engine. I can't even find it in the parts book, let alone on the engine itself. It's certainly not in the same place as it is on the 300 or 200 tdi's although it could be close and I just can't see it under the liberal coating of black oil all over the old engine!
Has anyone got a picture to show where it's fitted on the 2.5TD?
Nick.
Thank you both. I have now found it - it was indeed camouflaged as an oily mess, but I was not looking in the right place either.
For the record, the cold (25 deg. C) resistance is around 1.6k ohm, hot (100 deg. C) is about 125 ohms. Part number is PRC6663.
Nick.
