nickwilliams Posted June 29, 2010 Share Posted June 29, 2010 I'm clearly being very dumb but I'll be damned if I can find the engine temperature gauge sender on my old 19J engine. I can't even find it in the parts book, let alone on the engine itself. It's certainly not in the same place as it is on the 300 or 200 tdi's although it could be close and I just can't see it under the liberal coating of black oil all over the old engine! Has anyone got a picture to show where it's fitted on the 2.5TD? Nick. Quote Link to comment Share on other sites More sharing options...
Landy'd Gentry Posted June 29, 2010 Share Posted June 29, 2010 The tempreture sensor* is situated on the lefthand side of the engine block furthest away from the thermostat. Bulkhead +---+ |*O | | O | | O | | O | ++-++ +-+ RAD HTH Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 30, 2010 Share Posted June 30, 2010 I've only ever seen them on the right hand side - rear of the head, on the top Les. Quote Link to comment Share on other sites More sharing options...
Landy'd Gentry Posted June 30, 2010 Share Posted June 30, 2010 My mistake, it was late when I posted. +---+ | O*| | O | | O | | O | ++-++ RAD *is the temp sender Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted June 30, 2010 Author Share Posted June 30, 2010 Thank you both. I have now found it - it was indeed camouflaged as an oily mess, but I was not looking in the right place either. For the record, the cold (25 deg. C) resistance is around 1.6k ohm, hot (100 deg. C) is about 125 ohms. Part number is PRC6663. Nick. Quote Link to comment Share on other sites More sharing options...
