darak Posted July 25, 2010 Share Posted July 25, 2010 Hi my name is chris and a new member and req HELP. I have a 1999 v8 3.9 ,petrol have servise my disco changed plug leads as it would not fire up.Naw it dose and rev,s nice but when put into drive it cough,s and splutters,I do not know whot to do naw can anyone help. Many thanks. Chris Quote Link to comment Share on other sites More sharing options...
teabag Posted July 25, 2010 Share Posted July 25, 2010 Hi and WELCOME my first thought is that a lead/s are incorrectly fitted to the wrong plug/s. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 26, 2010 Share Posted July 26, 2010 If you've been trying to start it a lot and failing then pull the plugs and check they're not fouled with fuel, V8's are very fussy about that. Check you've got the leads in the right order. After that, if it's still rubbish then look at rotor/cap/coil/amp. Quote Link to comment Share on other sites More sharing options...
Ratty43 Posted July 26, 2010 Share Posted July 26, 2010 If it's running fine but failing under load I would suspect the coil, might just be a loose connection. Quote Link to comment Share on other sites More sharing options...
papasmurf Posted July 26, 2010 Share Posted July 26, 2010 My mini autograss car did this it was fuel starvation could be worth i know yours has 4 more cylinders but sounds like the same problem to me Rob Quote Link to comment Share on other sites More sharing options...
