Transfer-front output shaft
Hi
Been through the tech acrh but Im still wondering if it is possible to take the front output shaft easily? I need to inspect some possible wearing.
Or do I need to strip the whole box down?
cheers
M
nope no need to strip yet.
remove the prop and then remove the large nut which is VERY tight. You can then remove the front flange in situe. the output shaft can then be removed.
The thread below discussed this previously.
http://forums.lr4x4.com/index.php?showtopic=7812
