Help please, How do i get it off
Any ideas how to get the transfer box off the back of a defender gearbox
I've removed everything attached to it
I've removed the 4 bolts from the rear, and the two bolts from the front
But it will not move at all, not even a mm
I've been trying for over an hour now and it will not budge
Is there a trick to getting it off ?
what gear are you in?
try putting the transfer box in neutral, or moving it in and out of the gears
have you released the hand brake- could have bound on maybe?
i reckon you would have a bit of difficulty getting it off anyway (i did last imte i took an LT230 off a 5-speed box- can't remember which one it was)- try rotating the input shafts to free up the movement.
what are you taking off what anyway?
