landrover598 Posted May 31, 2006 Share Posted May 31, 2006 Any ideas how to get the transfer box off the back of a defender gearbox I've removed everything attached to it I've removed the 4 bolts from the rear, and the two bolts from the front But it will not move at all, not even a mm I've been trying for over an hour now and it will not budge Is there a trick to getting it off ? Quote Link to comment Share on other sites More sharing options...
pugwash Posted May 31, 2006 Share Posted May 31, 2006 what gear are you in? try putting the transfer box in neutral, or moving it in and out of the gears have you released the hand brake- could have bound on maybe? i reckon you would have a bit of difficulty getting it off anyway (i did last imte i took an LT230 off a 5-speed box- can't remember which one it was)- try rotating the input shafts to free up the movement. what are you taking off what anyway? Quote Link to comment Share on other sites More sharing options...
landrover598 Posted May 31, 2006 Author Share Posted May 31, 2006 It's an lt230 and r380 handbreak is removed I've left main box in first Transfer box is in hi diff lock Definately won't budge Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted May 31, 2006 Share Posted May 31, 2006 Anything useful here? Quote Link to comment Share on other sites More sharing options...
landrover598 Posted May 31, 2006 Author Share Posted May 31, 2006 This bit certainly isn't It came off nice and easily once the remaining bolt was out. As i said, the 4 bolts from the back and both of the two from the front are out Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted May 31, 2006 Share Posted May 31, 2006 This bit certainly isn't As i said, the 4 bolts from the back and both of the two from the front are out What about the bit about 1.2 ratio boxes? Does that apply to yours? Quote Link to comment Share on other sites More sharing options...
pugwash Posted May 31, 2006 Share Posted May 31, 2006 is there any movement at all? have you hit it with a large hammer yet to induce some movement? Quote Link to comment Share on other sites More sharing options...
landrover598 Posted May 31, 2006 Author Share Posted May 31, 2006 The sledge and crow bar finally got the bugger off Quote Link to comment Share on other sites More sharing options...
