Td5 engine to replace 300tdi
Hi Philip
The TD5 is a Euro III engine, so it is LEZ compliant.
My 300tdi has done 130000 miles and lacks power, as well as oil blowing out everywhere :(
The gearbox has a syncro problem with crunching gear changes.
The chassis is good and has a purpose made tipping body on it for tree surgery, hence the reason why I would rather pay for a TD5 engine/gearbox, than try and sell my 300tdi which I don't think in its present state would make much money.
I did see this on Ebay a while ago: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250539464590&ssPageName=STRK:MEWAX:IT
Anyone used them?
Cheers...Al
watch for insurence write off that cant be put back on the road
if u doin a totally different engine swop and want to get your car sorted for the lez they will be wanting engine numbers ect and if the engine cums from a written off car u may have problem
im probley rong but im sure sum 1 will correct me
Maybe its time to crack in a v8 with lpg?
conversion should work out cheaper than putting in a TD5 and i beleive the v8's are LEZ compliant. and shouldt be any more on fuel
Just a suggestion....
Now there's a thought! LEZ only applies to commercial diesel vehicles
i do like V8's - my other toy is a Triumph Stag with original 3.0l V8 !
