Keyfob resynchronisation with Nanocom
  • 1 year later...
Hi,
I need to Resynchronise my keyfob with the alarm ECU (Lucas 3TXA), Ive heard this is possible via Nanocom or equivalent???
Is anyone close to me (Warrington area) that can do this relatively cheaply?
Please PM me if you can.
Thanks
Jamie
Hi Jamie,
If you go to http://www.thed2boysclub.co.uk/forums/index.php you will find a nanocom/Hawkeye locator map on there site, I`m sure there will be someone neare you.
  • 2 weeks later...
yes, you can get the 10AS to learn the fob codes.
if you do know the codes, you can manually type it in thru the nanocom as well. at the (1-1), (1-2), (1-3), (1-4). each represents 1/4 part of the fob's code.
you will need all the fob you are going to have it to 'learn' at once. each time you do a 'learn' it clears out the previous fobs' codes.
