lapperz Posted September 29, 2010 Share Posted September 29, 2010 hi im fitting a rear disco axle off an L reg, on my 1986, 90. do i need to put my old diff on the new axle. so do you need to have 2 diffs that are the same. cheers. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted September 29, 2010 Share Posted September 29, 2010 Disco 1 diffs are the same ratio as your 90's one, 3.54:1, unless of course yours is non-standard. The Disco diff may be 24-spline too (stronger), as that was around the changeover period I think. Quote Link to comment Share on other sites More sharing options...
lapperz Posted September 29, 2010 Author Share Posted September 29, 2010 Disco 1 diffs are the same ratio as your 90's one, 3.54:1, unless of course yours is non-standard. The Disco diff may be 24-spline too (stronger), as that was around the changeover period I think. my prop connects straight up and i dont know if its 24 spline would it be still ok to use it cheers. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted September 29, 2010 Share Posted September 29, 2010 Its fine to use it, the gears are exactly the same. Given the prop bolted up its probably a 10 spline just like your old diff, as afaik 300series discos had the silly rotoflex thing. Quote Link to comment Share on other sites More sharing options...
