Souster Posted October 2, 2010 Share Posted October 2, 2010 Hi, does any one know where the fuel tank breather is on a 300tdi. Is it the pipe that joins onto the fuel filler neck? Ive heard that extended fuel tank breathers are used for wading. But, if it joins onto the filler neck wouldnt the tank fill with water anyway if the cap is not sealed? Quote Link to comment Share on other sites More sharing options...
western Posted October 2, 2010 Share Posted October 2, 2010 AFAIK, it's at the fill neck,you only need to extend the fuel tank breather if your wading far deeper than the recommended max for a standard vehicle. Quote Link to comment Share on other sites More sharing options...
Souster Posted October 2, 2010 Author Share Posted October 2, 2010 Thanks western. I was just going to extend it as a precaution really. Im not really going to wade much deaper than standard, so it should be ok then. How important is the timing case breather, as i have done everything else Quote Link to comment Share on other sites More sharing options...
western Posted October 2, 2010 Share Posted October 2, 2010 timing case breather is only worth having if you leave the wading plug in all the time, but it still needs to be removed to check for oil leaks/water ingress. Quote Link to comment Share on other sites More sharing options...
